Anyone ever changed the wires of Turnigys? -
02.20.2010, 08:17 PM
Hey guys!
I have 4 Turnigy lipos here of which I need to replace the wires!
Has anyone ever done this and has any suggestions on how to do this properly?
I sort of have a bad feeling while peeling of all the casings.
It is pretty easy to replace the wiring on Turnigy's because of the PCB. You just have to be careful not to apply too much heat for too long or the copper traces will detach from the PCB.
Because the 8AWG wires are to fat for the traxxas hcc.
And since I only need about 3cm of wire, I guess the higher resistance of the thinner cable is negligible.
What do you think about the effects of this PCB (besides easier soldering)? It seems a bit counter intuitive for Turnigy to use heavy duty 8AWG wire only to have this "bottleneck" so-to-speak of the thin copper traces on the PCB. Would getting rid of the PCB make any notable difference in performance?
From what I've seen on the 4s and 5s packs, the PCB is just there as a mounting point. The tabs themselves fold over each other, so there is really not much traces being used.
