02.23.2010, 12:05 AM
It would be simpler to use a LM317T vreg with a pass transistor, configured as a constant current source. The higher the voltage regulator rating, the more voltage headroom he is going to need.
You could also build a CC source using three diodes, a resistor, and a Darlington NPN transistor. This would require even less voltage headroom, but would also take a bit more design to do properly.
