Go Back   RC-Monster Forums > Support Forums > Slipperential discussion
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
02.24.2010, 08:10 PM
4-5mm would probably be too far back for many diffs - there is less than 4mm difference between most diffs and a 3.3mm hole that is 4mm offset from another 3.3mm hole is practically a slot. :)
Finnster
KillaHurtz
Finnster's Avatar
02.24.2010, 08:23 PM
Hmm... yea, I'm not sure how much shorter your slipperential is, just a guestimate based on the pix and the shim recc's.
The other idea would be to make a second set of mounting holes offset from the first. It would be a bit more of a pita, as the F diff mount would need more work, but could span a range of sizes from the long diffs, to shorter ones like the SlipDiff w/o tons of shims.
IDK, just a thought. I'm sure you will come up with something clever. :)
Here's a crappy pic of what I mean.
Name:	top plate.JPG
RC-Monster Mike
Site Owner
02.24.2010, 08:14 PM
The easiest way to modify would be to simply shorten the legs on the existing top plate - I made the legs long enough and drilled and tapped the holes deep enough to allow this as an option. If you remove a known amount and move the mount holes for the front the same amount on the template, you have a smaller package that fits smaller diffs directly. :)
nitrostarter
nitrostarter's Avatar
02.24.2010, 08:17 PM
Ah, beat me to it... This was my suggestion as well, I just wasn't aware of how deep the holes are on the top plate and if there were tapped all the in.
N. Rustler conversion
Finnster
KillaHurtz
Finnster's Avatar
02.24.2010, 08:24 PM
^^^ and that would be it lol
02.24.2010, 10:45 PM
can anybody link to shims to center the diff in the mount? They nhave to be narrow enough to allow the drive cup to pass through and I can't find any
jhautz
jhautz's Avatar
02.24.2010, 11:32 PM
Maybe use a 16mm OD o-ring as a shim.
to make it...
or break it...
Silent...But Deadly
adrictan
02.25.2010, 06:50 AM
I used these.
http://casterracingusa.com/product.p...7&cat=0&page=1
02.25.2010, 08:06 AM
Originally Posted by adrictan View Post
Thank you!
Kcaz25
Kcaz25's Avatar
07.28.2013, 07:32 PM
Thank you!
Hey Harold, this link doesn't work anymore. What do I need? Linky?
Thanks,
Zach
07.29.2013, 02:05 AM
Thanks,
Zach
You need 13x16 shims. Here's some on the bay> http://www.ebay.com/itm/Kyosho-13x16...item3383e5d17b
02.25.2010, 03:39 PM
You could also make the top plate shorter and have a few different spacers included to space out for longer diffs?
bdebde
That's All Folks!
bdebde's Avatar
02.25.2010, 04:10 PM
Seems easy enough to just cut the "legs" of the top plate to distance needed; I like it.
nitrostarter
02.25.2010, 04:37 PM
Thats what the big man suggested
