Semi Pro
Semi Pro's Avatar
02.24.2010, 10:41 PM
thanks
that was a very well spent $75
66794 REAR SHOCK TOWER (LIGHTNING 2 PRO EVO) 1 $7.00 $7.00
66797 ALUMINIUM REAR HUB (PURPLE) LIGHTNING 2 PRO EVO/LIGHTNING STADIUM 2 PRO 1 $9.00 $9.00
HB10809 FORD F-150 2004 1 $6.00 $6.00
HBC8011-1 FRONT HUB CARRIERS 22 DEG 1 $1.00 $1.00
HBC8075-4 FRONT SHOCK TOWER 7075 4MM PRO 1 $7.00 $7.00
HBC8104-2 FRONT SHOCK SET 3.5MM PR 1 $12.00 $12.00
HBC8040-2 6.7MM HEX WHEEL ADAPTER PURPLE 1 $1.00 $1.00
HBC8039-2 5MM HEX WHEEL ADAPTERS PURPLE 1 $2.00 $2.00
HBC8037-4 ALUM. ANODIZED CHASSIS 7075 1 $11.00 $11.00
66800 REAR SUSPENSION SHAFT SET (OUTER) LIGHTNING 2 PRO EVO/LIGHTNING STADIUM 2 PRO 1 $1.00 $1.00
66798 LOWER SUSPENSION PIN (CARBON STEEL/INNER/F&R) LIGHTNING 2 PRO EVO/LIGHTNING STADIUM 2 PRO 2 $1.00 $2.00
66212 LIGHTNING REAR SUSPENSION 1 $4.00 $4.00
61147 Hot Bodies Gumballs Worlds Spec Racing Slick Tires 2 $6.00 $12.00
also the have free shipping
