HOOH HUAH HOOH! Aww Baby!
02.02.2010, 03:50 PM
Benji - Get rid of the fans, get LPR or VTR low profile tires and wheels, get rid of the Rx box, get smaller (lighter) batts for racing...
That's All Folks!
02.02.2010, 04:16 PM
Originally Posted by Sower
What about the MBX6T or the D8T? Anyone have either of those?
I have a D8T in the works, chassis is done and converted (all electronics installed), just need to buy the kit to get the rest of the rig. It may be on hold till spring though, depends how finances are for the next little bit. Not many guys running truggy at the indoor track anyhow.
02.03.2010, 12:49 AM
02.03.2010, 12:57 PM
Looking good...
02.03.2010, 01:22 PM
Thanks for your comments.
I have fan only on the motor, the ESC have the original fan and 2nd cover to protect it from small stones. I live in a very hot country and the fan is a must.
As for the batts, will 4S 4000mA 30C be OK? my speed setup is for 35mph
http://www.hobbyking.com/hobbyking/s...idproduct=9511
02.04.2010, 02:13 AM
Depends - what kind of run time are you going for? Seems like most guys running 4s are using the 5000mah batts if I remember right.
Fat Kid Engineering
02.12.2010, 09:03 PM
Does this count, LST2/TRUGGY ?
9lbs 13.4 ozs w/o body
02.12.2010, 10:46 PM
Rear wing mount looks a bit heavy
02.16.2010, 04:36 PM
Anyone have a D8T or MBX6T weighed out?
02.16.2010, 06:32 PM
That's very nice Bondonutz! Did you made all those CF parts yourself? Oh.. and are that those HC connectors? How do they perform?
Fat Kid Engineering
02.16.2010, 08:30 PM
Byte, Thank You.
No, The CF chassis kit was purchased a few years ago, can't remember the Co's name. They are still around though, they had 2.5 & 3mm kits. Mines 3mm.
The HC plugs, LUV'EM.
They actually helped temps by a few degrees, The Deans plugs used to get warm(not hot) and these stay cool as ice.
Bonus is now my Bum friends who wrecked their Lipos with carelessness can't borrow my packs anymore. Had 2 get ruined last yr from lending, and have yet to be reimbursed.
They have a nice broad area to grab ahold of also, verses the little Deans.
Not knocking Deans at all,ben using them for 10+ yrs w/little to no failure but I Def like these jobbers better !
02.27.2010, 12:44 AM
Any updates on that D8T? I'd love to hear how it weighs in.
That's All Folks!
02.27.2010, 03:43 AM
Probably be a few more weeks before I get it all together, I'll let ya know.
03.27.2010, 12:30 AM
Caster F8T with CF towers, radio tray, steering plate, and top plates, MMM, Castle/Neu 2200kv, Turnigy HV767 Titanium servo, CC BEC, and two Flightmax 2S 5000mah 30C hardcase packs.
Weighed in at 9lb 4oz without the body.
08.06.2010, 12:05 PM
My Tekno MBX6T weighs in at 4.8kg RTR on 1 x 4s lipo, Tekin RX8 2000kv combo, 2 x Hitec 7955 servos, Spektrum SR3300T receiver, AKA tires, Kingheadz Front & Rear Chassis Braces & Kingheadz Rear Toe Blocks.
