Got brushless?
02.27.2010, 12:49 AM
roofles.
02.27.2010, 12:51 AM
What's the weight on that fatty?
Got brushless?
02.27.2010, 12:56 AM
It weighs 6.75 ounces (192 grams). Not too bad considering it's 3/16'' (4.5mm) steel. Possibly overkill, but I didn't want it to bend.
roofles.
02.27.2010, 12:57 AM
I'm dumb, but what's those spikes things for?
also guessing, those "shinier" spots are sanded down? Why not sand very lightly and get a nice shiny finish? Probably something else..
Got brushless?
02.27.2010, 01:34 AM
The "spikes" were actually supposed to be heatsink fins, since steel holds heat better than aluminum does. Seemed like a good idea at the time, but hey, they still look cool.
02.27.2010, 01:55 AM
Mmmmm.... Beefy!
Got brushless?
03.01.2010, 12:27 PM
Got brushless?
03.04.2010, 01:39 AM
03.04.2010, 01:52 PM
I didnt like it at first, but now its 99% there it actually looks rather smashing
What I would do is grab some of those tiny mini hand files and give it another going over, straighten up some edges and corners etc, then polish & clear coat it; too nice to cover in paint.
I think a solid one-piece version of this machined from a block of alloy ( a la UE mono-block ) would be even more awesome
03.04.2010, 02:36 PM
I agree with Neil. How come you didn't try to make it out of AL? You can Plasma cut it, and you can MIG weld it.....
Just curious if you noticed if the holes were any harder to drill? Plasma cutting tends to harden the material - but since you then welded it afterwards, that may have reversed that process...
Destroyer of Tires
03.04.2010, 06:41 PM
I like it. Its not as "finished" of a piece like you'd get from milling it out of a solid chunk of AL. But thats part of the beauty of it, function over form and making do with what you got on hand.
It would be interesting to see this mount done in AL, both monoblock style, and welded up in a similar fashion to what you did. But if you don't have a spool gun for your MIG thats not possible. Although with a few more screws for the bracing, this mount could be made with no welding whatsoever. Either way, I like the enginuity and the final product. Especially the bracing.
roofles.
03.04.2010, 07:03 PM
I believe he didn't use AL or anything else because he can get the hot-rolled steel quicker, and a more.....supply at once.
Don't want to give anything away incase he doesn't want me to.
03.04.2010, 11:58 PM
Actually, its quite possible. You just have to be careful to not loop your chord in too tight of a radius. I ziptied a piece of foam pipe insulation to mine to keep it "straight".
Destroyer of Tires
03.05.2010, 11:17 AM
Hmm, I just assumed the spool gun was for a different reason, tips, contaminating the chord, etc. While I like learning new stuff especially techniques like that, you suck, cause now I'm going to have to try it out and do projects I was putting off! Lol
03.05.2010, 11:57 AM
When welding material that thick with a mig (or pretty much any welding device) you will need to "V" the ends of the material where you want to weld. That way the weld penetrates the material properly. A bench grinder would do fine, just grind an angle on the piece, and weld in the V that you get when the place the ground piece against the flat piece. Looking at your welds the welder seem to be set about right for voltage, maybe lower the wire speed slightly.
Otherwise i like the result, not going to bend easily. Get good with the welds and you will not have to grind at all on them. I like a nice weld over a ground weld.
