sorry, mgm break problem....
tashpop
sorry, mgm break problem.... - 03.05.2010, 07:45 AM
can somebody shoot me some pointers here. i've been using the search, but i'm not sure i'm coming up with the answers. i seen on one post to tell the esc what pole motor i'm using, i didn't see that in the programing lititure. i'm using a mega acn22/45/2 motor. right now it seems to have a slow take off, but that doesn't bother me to save my slipper and diffs, but it seems to roll forever before applying the breaks. i tried to play with free wheel settings, and also break strength but it still rolls until maybe 10-15mph before applying breaks. this is a little dangerous and i don't want to power slide to break. i had a 16018 modle in a maxx before and overcame this same problem, but i don't remember how. this is the 22418 model and i'm pretty sure its the 3.23 firmware. programing is done by tx. thanks.
also, i am using fm radio gear.
Current Projects
CEN GST Mgm 22418
castle 1717
6s lipo
Losi Aftershock
Infinite 160a esc
Motor Not sure yet
TexasSP
Something, anything, nothing
TexasSP's Avatar
03.05.2010, 01:54 PM
If you can get the computer programming card it's much easier. I never bothered trying to program mine via tx b/c it was too involved.
www.cubicle101.com
tashpop
03.05.2010, 07:31 PM
i think i have the programming down, although it is a pain. i haven't tried the highest break setting yet, so i'll try that. now that i think about it, i had the pc linc for my last one. maybe thats when i got it to work right. hmmm.
Current Projects
CEN GST Mgm 22418
castle 1717
6s lipo
Losi Aftershock
Infinite 160a esc
Motor Not sure yet
bdebde
That's All Folks!
bdebde's Avatar
03.05.2010, 09:48 PM
Try resetting to default settings and reset to radio again. Make sure trim is at 0 and endpoints at 100 or 125 (brake adjustment at 100 as well).
tashpop
03.06.2010, 07:58 AM
what i've done was put the brakes on the next to hardest setting and put brake in neutral to med. it has worked, but i don't like how it drives this way. i'm going to take neutral brakes back off and if i loose my brake feel again, put them at hardest setting, and if that doesn't work, neutral brake at lowest setting. i think i'm getting close though.
krunk
03.06.2010, 10:44 AM
If you're still having trouble let me know. I have the usbcom for programming and updating the controller. If you have software v3.2 or above I think I have the stuff to update it.
ERBE MMM/2200
emaxx 9xl MGM16018
tashpop
03.07.2010, 10:03 AM
i think i just needed to remove neutral brake and turn regular brake up. seems to be working much better now
Current Projects
CEN GST Mgm 22418
castle 1717
6s lipo
Losi Aftershock
Infinite 160a esc
Motor Not sure yet
