The battery tray in that picture is actually a 45x168 w/esc shelf from my 'normal lineup', but the actual tray will be 50x160 inside with an esc tray - and it will bolt to the chassis directly(pre-drilled). The battery/esc tray is made of plastic, so you can either cut the esc portion off or substitute one of our regular trays with your kit if you like. :)
