sikeston34m
sikeston34m's Avatar
03.06.2010, 08:23 PM
Led's are becoming my latest obsession.
Here's an interesting tidbit for ya Bondo. I don't know much about the charger in question, but all you would need for this is some operating voltage in the proper range.
http://www.hobbycity.com/hobbyking/s...ip-White_(1mtr)
I have one of these in front of me. They are very bright. This strip comes to you a meter at a time. Within this meter, are 60 bright little boogers. Divided into groups of 3, they can be cut and used.
Cut, Wire it up, then all you have to do is figure out where to stick it. LOL
It's only about 3mm thick.
If your charger uses 12 volts as a power supply, wire it up to that. If your charger is getting power, then it's display is lit up.
Crap! I just realized you're talking a transmitter? Right? LOL
I'm not going to edit this. Now you can do your charger too if you wanna.
