Go Back   RC-Monster Forums > Support Forums > Slipperential discussion
Assembly question
chris_dono
Assembly question - 03.09.2010, 10:58 AM
Hey guys, was trying to assemble the slipperential last night and had a problem where the pin for the drivecup would not fit once the bearing/shim were in place on one side of the diff (the one that goes through the diff from the slipper side)
looks to me like there's not quite enough clearance. Have i assembled something backwards or is this just some fettling that needs doing ? I've tried the cups from the hyper st and the ones that came in the kit.
I did notice that the instructions say to put the pin through a hole, which is not there in the diff casing ?
Is it simply a matter of sanding the surface down to get enough clearance ?
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
03.09.2010, 11:21 AM
Chris,
I think you may have received a faulty end cap - we had a batch that wasn't properly machined in this area that we pulled out of inventory, but it looks like one escaped the shop here!
Regarding the pin - I install the inner drive pins before installing the diff cup so no hole is needed. :)
chris_dono
03.09.2010, 12:19 PM
hmm ok, so I'm ok to just sand it down until it fits then ?
RC-Monster Mike
Site Owner
03.09.2010, 01:37 PM
I will gladly send you a correct cap - you could try to sand the one you have down, but it is important to get it smooth and true in the process (best if done on a lathe).
chris_dono
03.09.2010, 02:31 PM
that would be great Mike, thanks
chris_dono
03.26.2010, 07:35 AM
Just wanted to let you know I received the replacement end cap, thanks very much Mike !
