kneedeeppow
is lovin life brushless
kneedeeppow's Avatar
03.20.2010, 05:31 AM
Originally Posted by malcster View Post
Youre lucky if you are only after a few more minutes as I need 20 minutes for our mains so need low KV motor and 5 or 6 cell batteries.
Doing my research if you wind the timing down on youre ecu to about 7 degrees and gear down and drop youre epa on radio down plus be careful with youre finger and maybe drop the lvc on ecu to say 2.9 volts per cell you can add a few minutes onto run time.
i was just reading your thread about 20 minute run times. thats a long final,i bet things get pretty warm by the end of that.i find my 2200kv has plenty if not to much power for what ineed.i find i waste a lot of power wheel spinning in the loose stuff so a slighty lower powered motor might be on the cards
associated rc8t..........e
tamiya f104pro,r,w.f103gt.tb02,ta02
nuova faor sf501
avatar is pic of what our cat does with empty boxes left over from rc purchases
