pinkpanda3310
pinkpanda3310's Avatar
03.20.2010, 08:44 AM
Hi! Threadjacker here. I'll try again. (It's alright, I'll forgive you 'cause your kiwi)
Motor kv does not refer to it's size. It is how many revs per volt (e.g. 2200kv motor on 1 volt = 2200 rpm). This page lists some motors of various sizes and kv. A point I would like you to note is the power ratings. Different kv's but still the same power output [e.g. 1515 1y has 2500 watts max power (Your castle motor is the commercial take of this motor), and a 1515 1.5y 2500 watts max power]
Power is volt times current (Volts x Amps = Watts). Higher kv motors draw more amps to produce the same power. 2200kv motors are suited to 4s - 2500w / 14.8v = 169 amps. 1500kv motor on 6s - 2500w / 22.2 = 113 amps.
So if you change the motor and battery in your setup (same size lower kv motor, higher voltage battery) you could expect to draw less amp draw, hence less heat, and over all a more efficient setup.
You will not see a decline in responsiveness or power when you trigger it. In fact you will have more power at your fingers because the lower kv has more torque.
Hope I helped this time
