pinkpanda3310
pinkpanda3310's Avatar
03.22.2010, 09:59 AM
Originally Posted by kneedeeppow View Post
-so larger mah packs make things more efficient?
-i am still search for that perfect throttle curve setting to give me a steady throttle 'roll'
Mah = milli amp hours, this is how big the fuel tank is, nothing to do with efficiency. The bigger the mah the bigger the pack, the longer the run time (with the same setup).
Learn to use a steady finger instead of flat out.
