I would like to see them have higher mah packs. 8k would be nice for my 2s 10th scale setups.
Considering most 8000+ mah packs are actually 2 packs just paralleled and packaged together. It's actually not a good idea and is problem since you are balance the 2 cells paralleled together as 1 single cells.
Now if they develop a 8000mah single cell, then sure!
Definitely. Would be great for early detection of problems. You could see a particular cell was starting to behave erratically and bring the vehicle in before anything worse happened.
the other bonus is it has an audible alarm right there on the radio when the cells hit the 3v/cell cutoff, so you know when to bring it in. no need to watch/listen for the lvc in the car/truck/heli/whatever and miss not hearing it (if you don't immediately notice a performance drop). plus it's only $60. i love eagletree, but their system like this is almost 10 times that.
Do they have the battery monitor for a 2 pack setup? That would be awesome on my Monster GT. I wonder it it provides real time readings too, so if you nail the throttle, you can see your voltage drop?
EDIT: Never mind, just read that it does provide real time readings. That is awesome. I need one of these but I need one for dual packs....
Seems like a very useful tool though, especially for people who race 1/8 electrics with a single pack.
All it does is plug into the balance port of the lipo. If you have multiple packs, just get a converter plug that takes you 2- 2s lipos and makes 1 4s lipo plug. Its quite simple to make as well.
