Looks a lot like mine. :) Although I'm trying to find a small box to put my receiver in.
Did you have any issues with mounting the front brace? I ended up having to grind out and move the braces upper mounting mount to the center, looks like you did too, then grind a bit on the RCM mount plate as it was a tad (less than 1mm) narrow.
