nitrostarter
nitrostarter's Avatar
03.24.2010, 10:37 AM
Keep in mind, the present day 1717's are equipped with 6mm shafts. CC is in the process of changing them to 5mm at the moment.
N. Rustler conversion
nuz69
nuz69's Avatar
03.24.2010, 10:41 AM
This timing issue disturb me, I have made a new thread about it, hope that some Castle Personnel will answer...
ANGRY-ALIEN
ANGRY-ALIEN's Avatar
03.24.2010, 10:43 AM
My 1520 is in my Muggy
Slipperential in the middle, 50K, and slipper tight.
5S Neu pack, MMM (dont know what settings I have it on right now)
50/18 gearing
I have only run it up and down the street a couple time so far, but its got plenty of power. Does NOT lift the front wheels off the ground, little slip on take off (dry pavement). But it does seem to run real cool so far.
1. I did put small washers between center diff mounts and chassis to raise everything up a bit for more clearance
2. I have the motor timing to 0
3. IMO the 1717 is too big for a truggy, heck the 1520 is a bit on the large size, but, I wanted a motor that I would not have to worry about. I was running a 1515 ccneu before and that was just fine as well
Hey guys... can you post photos of your 1520 setups... it will help to illustrate a 'clearer' picture on how you have modded your trucks facilitate this monster....
Oh yah + 1 on the 0 degree timing...
