Thread Tools Rating: Thread Rating: 4 votes, 4.00 average. Display Modes
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
03.25.2010, 12:35 AM
Originally Posted by Aero View Post
that castle fan is not a blower, its a YiMeng 7-bladed axial dc fan
Umm, "Blower" is the name of the product. Like "MMM" or "Sidewinder".
Yes, we know there are better fans available. No, I wouldn't pay twice as much for it because it had a better performing fan. Why? Because that expensive fan would still get eaten by sand/sticks etc. and would have to be replaced.
Oh, to the people complaining about it not being made from Aluminum- It isn't a heatsink. It's a shrouded fan. The CC motors already have a heatsink built into them. The Blower is meant to force air around the motor through the heatsink fins for better cooling. Making something like this out of Aluminum would be a waste of said Aluminum as there is not enough contact with the motor case to do any good. If you want some "bling" buy some chrome spray paint.
03.25.2010, 12:20 PM
A properly setup vehicle doesnt require a fan to keep the motor cool- if the motor is overheating it is either geared incorrectly or undersized/ underpowered for the application; people buy the blower because it looks cool mainly, and does offer a little bit of cooling to the motor. Given the choice I'd like a motor with a built-in fan ( lehner style ) and some form of air filter to prevent debris entering the motor vents.
lutach
lutach's Avatar
03.25.2010, 01:01 PM
I have to agree.
What's_nitro?
03.25.2010, 10:20 PM
I can agree to that as well. But I also believe cooler is always better. So even if your setup is running great, for the few hundred milliwatts the fan uses, if it can lower the motor temp by 10-20* or more I'm all for it.
its cool
Aero
Aero's Avatar
Smile its cool - 04.03.2010, 10:32 PM
good idea with the chrome spray..or green spray
I wasnt addressing you/we in particular, that probably are down with stuf . We also know that sidewinder and mamba are not snakes nor serpents. I was pointing out for those that dont know the part what it is, despite what it looks like ( a blower or a micro-V8 or..). And what better fan to get if say, the fan would RIP one day, or just want a better fan.
that 'fan grill' in short ruins the airflow and also makes the fan prone for carnage, as debris would have a hard time reflecting/escaping again. I recall a certain 'pinball beating' a fan got, a simple grill did that, costed some led lights, anyway..
It may be more matter of preference than whats 'best', using a fan grill, filter, or none. in a grill twigs could stall the fan and while it may not break the blades, render it useless anyway. If people want to buy fans or not: There are better fans and what one intend to pay, is sort of preference as well..
suicideneil> YOU! thanks for good help on BYT dude. i hear you on that fan-hate hehe. Overclockers might not agree, replace a MMM fan with a sunon and you get 10 degree lower temps, translate that into power. That Castle made the fan trigger instead of running all the time, could that be a way to extend fan life, far out translation ? lol. it saves the batteries/bec but thats about all. Some people bash in -10-15 celsius, others in +33 celsius all year long, Im inbetween with cold winters and hot summers, still i like to use fans, i believe it helps any efficiency there would be to gain.
it can be a neverending argue, but we're not all 'supposed to agree' anyway!
for the record, "I agree, but = I don't agree, but".
what is 'overheat' - one can blame the motor, the esc, the lipos...if you can keep things cool and gain performance, whether a truck is 'too heavy' 'too much geared' or whatever, cooling is a helping hand that dont mind the method of torment, its like red cross in a war
maybe its good to say this, there a thing to it: fan cooling it not a way to 'lower the temps' as such, meaning lower temps can be achieved in some setup, regardless of whatever fan cooling is present. but at any right/best gearing/setup (all in all) its still a beneficial method to get better efficiency/performance/runtime. So in a way fans could be left out when trying to find a best setup, and after that, plug in the fans
What's_nitro?
04.03.2010, 11:00 PM
I can see how the fan grill could be problematic. Even without the "pinball effect" if a small stick were to get lodged in the grill while the fan was off, then the fan would not be able to start at all. That would relate more to the MMM than the CC Blower, but you get the idea. So far I haven't had any problems with my fans, but if I did I'd cut out that grill and replace it with some stainless steel mesh bent into a dome shape (think turbine intake).
