03.29.2010, 10:10 AM
Having thought the same at one point and splashed the cash... They are a bit of a pain to get on and off - After a few swaps chances are you will strip some threads ruining the wheels...
If you have a reasonably powered setup chances all you might not be able to hold a bead under brushless assault...
Easiler in long run to just glue IMO...
thzero
03.29.2010, 10:39 AM
Well I have them. They are a PITA to get on and off, and as Arct1k mentions you gotta be careful not to strip them. That being said, I've had no issue running them on 5S/2200kv power in two bashing sessions. Although the second one did end up a bit short due to collision with a solid object.
