Thread Tools Rating: Thread Rating: 9 votes, 4.11 average. Display Modes
04.05.2010, 11:38 PM
Keep in mind that this is a 2wd vehicle and just cannot load the motor like a 4wd can. So the 1527 should be good to go. I would like to see a specific carbon fiber chassis done for electric, as the stock chassis setup is not really all that good and requires alot of bracing. A lighter weight baja with 1527 on 8s power would be great. should be able to get down to around 15lbs, methinks.
I plan to make a lst based buggy (4wd) that would be close to 5th scale, maybe 6th? I will use a 6061 channel that is about 4" wide and has 1" sides. Plenty stong and narrow. Just need to get back into rc...
