rootar
rootar's Avatar
04.19.2010, 10:25 AM
glueing tires is like painting, it comes down to the prep work and wether or not you know what your doing. With a properly set of glue tires the the tire will actualy rip at the sidewall rather than coming loose at the bead.
jayjay283
jayjay283's Avatar
04.19.2010, 07:44 PM
AhMEM SISTAH... if you dont slightly at least scuff the side walls before applying whats Texas Sp called zip zap glue... #1 scuff #2 glue # 3-4 smoke a beezer and reapply the glue ...1 pass of sticky glue and your finger gets stuck so you quit NANCY, you need 3 -27 layers of glue on the wheel, I run 6's all day. Purchace some beadlocks and zip it
