its the same as the hobbyking one but i guess it will do 6 amps instead of 5. i have the hobbyking one and it works great with a 25a power supply. same as the new imax one, software and everything. works very well on 2-6s packs and yes you do have to supply more balance boards if you run anything other than a jst tap otherwise it plugs into the side of the charger.
