What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
04.28.2010, 03:26 PM
Well, all I can think of is use more foam under the ESC. Try 1/2" of foam and see if it helps cushion the landings. What kind of foam is it? Weatherstripping works well as it has some memory foam-like qualities. If you're using the normal gray open-cell stuff it probably isn't providing enough cushion.
