Proline BadLands strechted Rulux Half Ups
Nard Cox
n00b
Proline BadLands strechted Rulux Half Ups - 05.01.2010, 02:56 PM
Hi guys,
How to glue my Badlands stretched on my Rulux Half Ups:
This:
or this:
What do you guys think / run?
Fast response would be great since I would like to run these puppies tomorrow.
Thanks!!
EDIT: And what about my foams :
Is the right on still usable?
EDIT: On the Traxxas forums (yeah I know....) they prefer the inside method : click
bdebde
That's All Folks!
bdebde's Avatar
05.01.2010, 03:26 PM
I would put them in the bead. As far as the foams, give a try with a hair dryer/ heat gun on low to expand that foam, careful not to melt them. If it comes back, run it, otherwise I would replace them.
Nard Cox
n00b
05.01.2010, 03:28 PM
They have been lying around for about 4 days now. They are completely dry.
EDIT: I read that it's also a way to reshape the foams back. Going to try that now, thanks for the tip!
05.01.2010, 04:48 PM
Washing and then drying them normally gets them to fluff back up
Semi Pro
Semi Pro's Avatar
05.01.2010, 05:05 PM
if they dont fluff back up then dont use them, glue them on the bead
Nard Cox
n00b
05.01.2010, 05:20 PM
@ Arct1k, I've cleaned them with water (incredible how much sand was in there). When I wanted to pull the wheels of the rim (after boiling) the two with the strange foams seemed like they were sucked vacuum. Should I wash them with any ''special'' stuff?
@ Semi Pro, so the normal way.
reno911
Smelly Nitro meet your maker!
reno911's Avatar
05.01.2010, 09:59 PM
I mounted mine on the inside like picture two. Slightly narrower and performed well.
mistercrash
Guelph, Canada, eh!
mistercrash's Avatar
05.01.2010, 11:43 PM
These two drawings were made by me. I made them from my own experience with Badlands on Rulux half ups. If you mount them on the usual outside bead, your side walls will be squished and look very weird because the whole tire has to be stretched. If you mount them on the inside bead like in pic #2. part of that side wall will be inside the rim and basically you will end up with a low profile Badland. Like the Proline LPR tires and rims.
The drawing is not representative of what really happens when you use the inside bead. The side wal will rest firmly on the outer edge of the rim and you can run a second bead of CA all around to seal that joint which will make your side wall firm and will make the truck handle very well and very stable.
The only downside of this tire/rim combination is mounting them. Those tires have to be stretched to fit on that inside bead and your fingers will hurt once your done.
I loved this set up so much that I ran these Badlands exclusively while bashing until there were no more treads on them.
Freshly mounted Badlands on Rulux half Ups using the inside bead.
A couple months later. I loved this combo. Gotta get me another one soon.
Here's a pic of Badlands mounted on LPR rims (or half ups) on the regular bead on the left and inside bead on the right. The regular bead looks weird and bulging. The pic is from someone else.
No brain, no headaches.
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
05.01.2010, 11:58 PM
When will Proline make a set of basher type tires in LPR size? Everyone seems to lve the badlands but mounting them to LPR rims is a PITA.
ANGRY-ALIEN
ANGRY-ALIEN's Avatar
05.02.2010, 01:52 AM
Can this mounting method work with Proline VELOCITY dish wheels? I love Badlands, but i just hate that the side walls offer no real support.
Nard Cox
n00b
05.02.2010, 05:26 AM
@ reno911, I'm also leaning towards that.
@ mistercrash, it's final. Inside bead with a layer of glue on the outside. I've already mounted two of them on the innerbead. I think it wasn't so hard to mount when. Ok more difficult than a normal one, but it's do-able (I did brake a finger nail though ). I also love my Badlands, they look badd-ass and offer tons of grip offroad.
@ ANGRY-ALIEN, I don't see why not. The beads are exactly the same.
ANGRY-ALIEN
05.02.2010, 12:49 PM
Zeen... I will give it a go then when they get here... thnx man
Alien
reno911
reno911's Avatar
05.02.2010, 12:52 PM
The proline wheels are the correct size for the badlands, but I would assume you would be able to glue them on the very inside of the first bead.
As for sidewall support, I relied on my revos suspension to cure that ailment. With proper suspension setup I don't think having stiffer side walls will be noticeable. Besides the tires may be a part of the suspension. In my eyes they are just there to make traction, the suspension is supposed to do all of the work to insure that the tires have traction. For those who know, the badlands get some awesome traction, pretty good on asphalt as well.
Nard Cox
n00b
05.02.2010, 12:56 PM
My bad, if they are 3.2'' I would glue them like they are meant to be glued.
ANGRY-ALIEN
05.02.2010, 01:12 PM
hmmm... so what you are is, proline wheels might not work as well as the Rulux wheels did?
