@ all - thanks
@ rc4x4nut - Yes I think about a conversion kit but not full. Only for the normal Nitro-LST´s. There are so many things I arranged in the gear box. The motor mount is so complex. I don´t want to build it again.
@ JAILBIRD - I use VHM tolls (VHM = Full Harded Metall). We used it normaly to cut hardened steel (about 58-62 HRC).
If you toke normal tool stell cutter it´s blunt very fast. Speeds and feeds - very slow! It´s a matter of feeling. Also lining. Carbon is so disgusting.
And don´t forgett to exhaust! We have a very big exhaust system. It´s the big pipe you can see on the pics...
and the smaller one I normaly use for this stuff
olli
