Originally Posted by squeeforever
Not really sure, but the only problem I would worry about is if that same thermal resistor controlled the thermal shutoff. In the event it got extremely hot for some reason, it wouldn't shut itself off. Like I said, I'm not sure if Castle uses one for the fan and another one for the thermal shutoff, or one for both.
Hi Squee,
How've you been doing? Long time no see.
I'm pretty sure there are two thermistors involved since the fan comes on at one temp and thermal shutdown occurs at another temp.
Two setpoints would require two thermistors.
