Cartwheels
05.09.2010, 06:21 PM
An other thing you may be noticing is the fact that batteries can better flow the juice when warmer. Your batteries may be warmer now then over winter due to warmer ambient temps. Sometimes if the temp change is drastic enough, it may even require a gearing change. In your case dropping a tooth might make sense depending on the situation.
