05.13.2010, 09:30 AM
Interesting design, but by the looks of it you will have the battery mounted in the rear?
I would suggest that you mount the battery up front, as having the battery weight there will help counteract the gyroscopic force of the heavy tires when you are in the air and on throttle. If you have the weight biased backwards you will always jump way nose high and have to use the brakes to land properly.
I am working on a stretched chassis setup for savage at the moment. I kept the tranny and flux style motor mount/location. Added the extra length in the front and will have the battery tray act as a servo mount as well. Still need to cut the second tvp and make the battery tray. Bandsaw broke so I have to scare up some parts!
