nitrostarter
nitrostarter's Avatar
05.14.2010, 11:53 AM
Definitely opt for the Tork motor if you can. Quality is always preferred. Should run nicely with the MMP in this buggy.
More than likely the oil slung is because of a loose screw or poorly seated gasket on the diff cup. Check there and make sure to top off the fluid while you're at it.
N. Rustler conversion
