DwightSchrute
I'm obsessed with The Office
DwightSchrute's Avatar
05.20.2010, 02:32 PM
With the original V1, guys ( me included ) dremeled a bit of clearance on the bottom half of the case, underneath where the BEC coil is located. The V2 had a foam pad underneath the coil ( inside the case ) but Im not sure if it helped a whole lot- not sure if the V3 & onwards have extra clearence or not....
Neil,
I opened it up and i could see a faint mark on the bec and case bottom where the case had hit it. More specifically, i could feel a rough spot where i believe the top of the bec had hit the manufacturing sticker on the bottom of the case. So i think you're right, there needs to be some extra clearance there.
i know the cases from V2 to V3 and 4's were supposed to be a few mm bigger, but i'm wondering if it was enough for some of the bigger jumpers who might get more case flex on harder landings.
i've got some good suggestions from you and a few other folks about how to tackle the problem. i think it's definately fixable.
thanks for the replies guys.
8IGHT 2.0 2650KV MMP
LOSI TEN SCTE NOVAK 3700 MMP
B44 MMP TRINITY D3 6T
B4 MMP TRINITY D3 9.5
E-REVO BRUSHLESS EDITION
