UE Supermaxx Addict!
05.21.2010, 09:04 AM
$10 flat-rate...the bones are the same for both the 6mm and 8mm CVDs, so a bone for ither size will work, you just have to find one. You will most likely have to buy a full-set (you can buy 6mm CVDs and swap the 8mm axles onto the bones). It won't be easy, but keep searching the this forum, the UE forum, & eBay.
Are you CVDs steel or titanium?
-Chad
› PM ME IF YOU HAVE THE BELOW:
› VBS, CVDs, GM Single-Speed, OTB, Ultramaxxed, Super6, Strobe, Sprong, CNR Brake, UE Hex, DUH Towers, Predator, Blackbird, GA Blue Screws, HCR F/R Skids & Mutant
