ptt81
05.21.2010, 04:34 PM
well in that case I will stick with my 2200kv and 48/14 since thats what I already have and it sounds like it is a good setup as well. I'm just a basher, no racing on track so I think 2200Kv is better for me as far as temp goes, I live in TX so its also hot here during summer.
Ok here is a vid showing the play problem. The same problem remain on or off the chassis. This has nothing to do with the front or rear shaft, just the mount and center diff itself.
http://www.youtube.com/watch?v=6biZnoiiH9U
I found that the grove where the bearing goes into is cut a little too deep on the RCM, stock mount does not have any play. May be i got a defective mount? because no one that have RCM mount seems to have the same problem as me.
