Mamba monster wont except sync -reverse
SpeedAssault
SpeedAssault's Avatar
Mamba monster wont except sync -reverse - 04.12.2010, 11:04 PM
I have done this many times, different cars different receivers.
Right now it works fine on my novac 27mhz & airtronics tx. But I am trying to re config with a Spektrum DX6i and AR6100. I get the Green flashing so I pull full forward throttle, then get the red flashing light and beeping so then you go full reverse, but the ESC never excepts it.
The process is the same as using a Mamba max.
I have changed throttle trim, ESC dead band setting from large to default 1000ms
How do I get this DAMM thing to Sync ! ?
Wasted an hour of my time tonight.
I am getting really Sick & tired of dealing with these syncing issues, even had to send it back once before.
Thanks guys
BP-Revo
BMW M Power!
BP-Revo's Avatar
04.13.2010, 12:07 AM
The DX6i is an air controller, the Mambas are ground controllers.
04.13.2010, 06:14 AM
That's not it I use the dx6 / ar6000 with mm and fxrs with no issue.
Check the end points on the throttle.
SpeedAssault
04.17.2010, 11:51 PM
it is my bad.
My new Dx6i pistol conversion was limiting the reverse trigger, so I trimmed the case a bit.
All Fixed
The Dude
No Way....
The Dude's Avatar
05.22.2010, 10:40 AM
I've got the same trouble on my MGT...
I've got a MMM and a DX6i (AR6200), and the controller don't reconize the radio....the 3 leds flashing with a Beep by second...
anyone have a idea ???
05.23.2010, 08:32 PM
I have a DX6i & MMM too. When I installed mine, I used an rx battery pack to power the rx in order to bind it to the tx, then plugged the esc into the rx to calibrate it. Providing your epa and throttle travel etc are all at default settings you shouldnt have any issues calibrating it:
power up the esc & rx
pull full throttle
turn on the tx
wait for beeps/ leds to change
pull full brake
wait for the beeps/ leds to change again
release to neutral
the MMM should beep the full arming tone indicating its calibrated.
Only possible problem really is that the arming time is quite short on the MMM as standard, so use the castlelink to raise it to 2-3 seconds and try again.
The Dude
No Way....
The Dude's Avatar
05.24.2010, 02:01 AM
thanks ...i find the solution.... I was in heli mode so there is some mixing by default....
but I gonna buy a another pistol radio...IMO a stick radio is great for crawlin', not for bashing..
