Pdelcast
Pdelcast's Avatar
05.25.2010, 01:15 PM
Any chance of a Castle Brushed Crawler ESC or is this out of the question due to the business relationship with JRH?
You have the capabilities and boards to be able to combine a CC BEC Pro with 2 MM Pro or BR-XL boards...
You could then bridge the two brain boards so that you have the option of:
- Operating the two boards fully indepently for people using 4 or 6 channel radios
- Operating the boards linked where both take throttle signals etc from 1 RX wire and the second RX wire plugs into the Aux to control dig/burn/4x4 ie just uses the 3pos switch to disable/sets to neutral the throttle input to one ESC.
This would provide the ultimate crawling esc for MOA rigs... I hope you guys were watching but Axial just released an MOA kits. This means Losi isn't going to be far behind offering an MOA conversion...
Everyones going to be looking for an ESC that does this... Happy as always to Beta
The Novak M2 will actually be close to this but I havn't seen Novak have the software to match CC and I'm sure the BEC will be not be enough and the SC will max out at 3s...
Thanks for listening...
Cheers
OK -- how about:
A separate board that would:
link two Mamba Pros together, combining the BEC outputs (doubling the BEC) and acting as a throttle mixer for the two MMPs...
We already have the software for RX channel mixing available (we wrote it a few years ago for the Berg receivers) so it would require hardware and just a little bit of development.
This would be much simpler than designing a double ESC.
Patrick del Castillo
President, Principle Engineer
