itbvolks
05.26.2010, 07:30 AM
Ya, checked all my driveline stuff. Smooth as can be.
Running the same setup right now. 15/46 with Mikes slipper.
Track is/was pretty tight/technical throughout the infield. Good straight. Loose track conditions so might have just been free revving some. I'm thinking I might go back towards the linear throttle profile to aid in mid rpm/mid throttle drive.
I also have no current limit setup right now. Timing is at zero. No drag brake or push control. LVC is set for 3.2v/cell.
Going to give the connections the once over again and see if anything sticks out.
