florianz
09.24.2009, 05:42 PM
just recently a guy's castle-neu rotor exploded. and my losi would have exploded as well, if I didn't seal the rotor bonding which was getting loose due to sand. even the lehner's loosing segments... they all can fail. but when the arc's not bonded, that might be a problem. I can't forget that statment of the 75mm on 8s. surviving that, I think they're solid, but I think we wil find out
brian015
brian015's Avatar
05.25.2010, 01:26 PM
So has anyone tried one of these ARC motors out? I saw this advertisement which claims they now have "REDESIGNED ENDCAPS FEATURING RETAINING CLIPS TO PREVENT ENDCAP FAILURE FROM THE EXTREME FORCES THESE MOTORS GENERATE":
http://www.lightflightrc.com/
brian015
brian015's Avatar
05.27.2010, 07:53 AM
anyone?
killajb
killajb's Avatar
05.27.2010, 08:07 AM
I have one of these in my muggy. I haven't run it very much because of work has been picking up. I'll run it this weekend and give you more details, temps, gearing, etc.
brian015
brian015's Avatar
05.27.2010, 09:40 AM
Thanks, any general impressions would be helpful.
killajb
killajb's Avatar
05.30.2010, 11:02 PM
Took my Muggy out bashing today. MMM 6s 4000 30C Zippys. I have the 36-75-1 ARC motor with a heatsink/fan combo on it from Hobby City, exactly like this:
http://cgi.ebay.com/540-Brushless-Mo...item255adc159c
Running 15-tooth pinion, 46-tooth spur. Don't think the fan is really necessary, but since I purchased 5 of them at one time, I put them on most of my 1/8 conversions as a precaution. They seem to lower temps an average of 20 degrees (F). Wheels are large (and relatively heavy) Hot Bodies wheels.
I ran in an open parking lot which is surrounded by steep, grassy hills that lead to adjacent parking lots. I consider this worst-case scenario as the vehicle is run in either wide-open throttle in the open parking lot, or being bogged down in tall grass (as tall as the wheels) going up steep hills.
Temps after 20 minutes of this were: Motor 153.5 F, Battery 121 F ESC 132 F
Motor has plenty of torque and throws the Muggy around nicely. Center diff fluid could be a little thicker as the front tires ballooned if I pegged the throttle. I could flip the truck on its lid from a standstill as well. Overall the motor seems a more powerful than my CC 2200, NEU 1515 2.5 D or my Hacker C50 11XL. Temps were lower in this setup than the CC 2200 and Hacker motor, but on par with the NEU 1515 2.5 D.
I covered the cooling holes with aluminum tape to prevent dirt from damaging the motor. Overall, for the price I'd consider this a good alternative for a larger 1/8 scale vehicle or monster truck. I didn't have many hard impacts, so I cannot verify if the end caps would pop off during a hard crash or not.
Hope this helps!
brian015
brian015's Avatar
05.31.2010, 06:47 AM
Hope this helps!
Yes it does - good to hear from someone who has actually used it. Thanks for the data.
brian
