25C Poly RC Lipo getting hot at 16C peaks
skellyo
skellyo's Avatar
25C Poly RC Lipo getting hot at 16C peaks - 05.30.2010, 07:18 AM
I posted this on a boat forum regarding some Poly RC packs I recently ran in my boat.
I picked up a Mini Cat Racing Velocity Mono several weeks ago and 3 - 3S 25C 2200mAh Poly RC packs for it. I expected these packs to run very well in this boat. However, I was very disappointed with how hot these packs were after running. One run a pack hit 148F! To be sure I didn't have an unexpectedly high current draw, I picked up an Eagle Tree datalogger and ran it for a few minutes this morning to get some data. It backs up my assertions that the pack just isn't that great. However, it does hold voltage at ~3.6V/cell at the highest current peak on my plot, but that's at only ~16C from a 25C continuous pack.
Has anyone else had issues like this with a pack where it's used well below continuous C rating, but still gets way too hot?
Andrewg
05.30.2010, 09:54 AM
could the label on the pack overstate its capability? Its the old story pay peanuts get monkeys.
TexasSP
Something, anything, nothing
TexasSP's Avatar
05.30.2010, 10:16 AM
Poly rc is hardly known to be a low end pack so I am rather surprised. I would be curious to know which cells they are using in these. I have never had this issue from a higher quality pack like this. In fact maxamps were the only ones I have ever had issues like this with.
www.cubicle101.com
asheck
05.30.2010, 11:19 AM
Are they in an enclosed space, where excessive heat just builds? How much capacity was drained to reach that temp? Also in comparison to land vehicles, isnt the average, quite a bit higher in relationship to it's max amp draw?
skellyo
skellyo's Avatar
05.30.2010, 11:45 AM
It is an enclosed space, but they are the hottest thing in the boat. The motor and esc are a good 30F lower in temp than the lipo, so the ambient air around them isn't causing the greater increase IMO. I think the best thing to try now is different lipos. The boat runs great, I just totally wasn't expecting hot batts when they're not being discharged at even close to their C rating.
scarletboa
scarletboa's Avatar
05.30.2010, 05:21 PM
try some nice turnigy 40c packs. they are dirt cheap and i would be very surprised if they broke 100F.
or, you could get a hyperion 35c or 45c pack.
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
05.30.2010, 07:21 PM
How old are they? The cells may just be worn out, and can't put out the amps they used to.
*edit* Duh...answered my own question. Sorry....
So they aren't old to you, maybe they were on the shelf a bit too long?
Andrewg
05.31.2010, 02:26 AM
PolyRC has a lot of grades of cells as do most companies
It may be an older gen pack pack - which ages them and increases internal resistance
Also cell heat isnt bad as long as they come about in the 50 celcius range - preheating to 45+celcius reduces the internal reistance and delivers a definite boost to voltage under load.
Finally continuous/peak ratings are arbitrary. nothing runs continuous amps and only LMR gliders nd drag racing run real peak amp loads.
Altho I use Thunder Power in all my marine racing I use the continuous rating as a peak rating. I only hit it when i enter a turn at full speed. i run the same course every time and take out 2300-2600mah from a 5000mah pack in 60-80 seconds the packs ciome ina t 45-50 degrees celcius
