IGT_7x
IGT_7x's Avatar
06.02.2010, 11:39 AM
Thanks for all the compliments. Yes a Tekin will fit because it's about the same diameter as the 1520 and there's a little bit room to spare. As far as the no wheelie thing, my front end feels heavier than the back end even when the battery & motor are in the rear, also if you do use this kit mount the battery on the top tray instead of the lower so it's not so far back. I've always imagined that the beetle body would look good on the LST so thanks to Proline for releasing the body.
