One last time to see if any of you guys want these. I'm not sure if I'm just asking too much for the Night Crawler or what, but I need to sell it. If you know someone that wants a good crawler with great potential, please put them in contact with me.
Airtronics M8 2.4Ghz setup, two of the Air small receivers (the $100 units), NiCd battery, charger, aluminum carrying case, everything is in good shape except the battery door which broke in half but doesn't effect charging, use, or anything at all other than it doesn't cover the door. I can package this with the RC8T or the crawler, no big deal. Rxs have no antennas. This is going for pretty cheap too, you're basically buying one receiver and getting a 2.4Ghz setup, Rx, and M8 with case for free.
Team Losi Night Crawler turned into a very competitive and capable crawler. Has been lowered and the battery box was taken off. I have all stock parts still including the lights and all hardware. I also have the stock electronics. I'll be selling it ARTR, add Tx and Rx for now since it's already together. Has some lead in the stock beadlocks although I would take some of it out as it's a lot. Has white dot Rovers on there, those hook up like mad. Running a Mamba Max Pro that I bought new a short time ago with a Holmes Crawlmaster on 3s. Has two Hyperion 1200mah 3s packs that are ridiculously great on this rig. Also has a Hitec 5955 servo for plenty of turning power. Body has some battle wounds but no rips or tears. This thing crawled beautifully and I love driving it, it just goes up everything now.
Quick rundown:
Night Crawler with mods
two 3s Hyperion 1200mah lipos (5 runs each)
Mamba Max Pro
Holmes Crawlmaster 1000kv (goes up anything)
white Rovers
weights in beadlocks
only 1 month old, still have the box!
Hitec 5955 servo
stock tires, electronics, etc
I will part out but ONLY if the roller sells first! I'll edit the ad if/when that happens.
Nylint 1/6 Jeep body. This is in good shape and complete. Unmodified. Shipping will be most of this, so I'm asking
Mad Force Axles, these were for the 1/6 Nylint body but I keep getting sidetracked and I don't think I'll ever get around to making a super scaler.
(Beadlocks are gone)
