Some progres:
Motor mount ala Lincpimp:
Its 2mm HD steel... I couldn't bend anything thicker. In order to avoid damaging the thread I made in the steel sheet I'll add some M4 screws on top of it. Actually I could just have made some straight holes and added the screws after...
Yes it
can wobble a little... a little :) I'll have to add some sort of support in the rear. However it can
only wobble vertically. Not horizontally... so it should be pretty easy to fix.
Drilled a hole in the bend line to get the motor as low as possible:
I can mesh 13-19 tooth pinions as it is:
Chassis with battery trays:
Tested it a little around the parking lot with the KB on 3 cells. looked good :)
