Questions about XMODS (electronics & dying parts)...
Chadworkz
UE Supermaxx Addict!
Chadworkz's Avatar
Question Questions about XMODS (electronics & dying parts)... - 06.09.2010, 10:35 PM
Ok, I got a new XMODS Evolution Car, and am going to replace the electronics with a Spektrum SR3500 Rx, Novak Spy Micro ESC, and LiPo batteries. It already has a Stage-2 Motor which is pretty fast, but I might see if I can find a brushless system that will fit. Anyway, my biggest question is what to do about the steering...you can't just stick a standard micro-servo in there because XMODS aren't setup that way, so I was thinking about using an old micro-servo to power the servo-motor built into the car...
[1] If I take the wires off of the motor inside the servo, and connect them to the servo-motor in the XMODS, will it work correctly?
[2] Also, does anyone know if you can dye the parts on the XMODS? I just don't like the bright green suspension arms and light & medium gray chassis, and would love to dye everything black.
-Chad
PM ME IF YOU HAVE THE BELOW:
DCastaneda
Speed Addict
DCastaneda's Avatar
06.09.2010, 10:51 PM
not sure on the xmods but atleast on the kyosho mini-z's people will take the logic board from a micro servo and hook up the + and - to the servo motor and then the three remaining wires (to the servo POT) to the POT on the mini-z itself.
Durango DESC410r MMM CC/Neu 1410
B4.1 Worlds MMP RevTech 17.5
SC10 MMP RevTech 17.5
XRAY T2R MMP Duo3 10.5
SC8E MMM CC/Neu 1520 6s
Inferno GT HV- W.I.P. 12s CC HV110
  Send a message via AIM to DCastaneda
Chadworkz
Chadworkz's Avatar
06.10.2010, 12:16 AM
Ok, thank you...the XMODS has an external pot on its board as well, so I may have to switch the 3 pot wires along with the motor [+] & [-]. Again, thanks.
-Chad
Chadworkz
Chadworkz's Avatar
06.10.2010, 09:12 AM
Ok, so the pot on the XMODS board is not like a standard pot, or even the pot on a Mini-Z board, so I have another idea...
...since I can't just unhook the wires from the micro-servo motor and hook them to the servo-motor in the XMODS, because that takes the pot out of the loop, I thought I could keep the wires attached to the motor in the micro-servo, and then just run parallel wires to the servo in the XMODS...that powers the servo-motor in the XMODS, and keeps the pot in the micro-servo in the loop.
Do you think this will work?
-Chad
DCastaneda
Speed Addict
DCastaneda's Avatar
06.12.2010, 02:09 PM
What is different about the pot on the xmods? Your idea may work i have my doubts as to how effective it may be, not to mention you'll be drawing more current to feed two servo motors. If worst comes to worst, just shoehorn a micro servo in place of the stock garbage HPI electronics, lol.
whitrzac
Can't catch this...
whitrzac's Avatar
06.12.2010, 08:04 PM
I'v done this just for kicks, but its a PIA...
the 3 wires off to the left side of the board connect directly to the POT, take the board from a micro servo, take the pot and motor off, and wire the xmods ones in.
Chadworkz
Chadworkz's Avatar
06.14.2010, 01:35 AM
The XMODS are not made by HPI, they are made by Radio Shack...also, they do not have standard electronics, or anything resembling a standard steering servo...it's just a small motor controlled by the main circuit board that controls everything else. Also, the hobby electronics I am putting in would be more than enough to power 2 servos.
I am going to try this and see how it works...I will let you know!
-Chad
DCastaneda
Speed Addict
DCastaneda's Avatar
06.21.2010, 03:52 PM
That's exactly what i said to do.. lol. And XMODS are MFG'd or atleast were by HPI. Do a little research. They had a Subaru Body for the XMODS painted in that Orange/Yellow theme that HPI made for one of their 1/10 sedans too.
Chadworkz
Chadworkz's Avatar
06.25.2010, 11:24 AM
I wasn't dissing you in any way, DCastaneda, it was more of a confirmation.
-Chad
Tags
brushless, xmod, xmods, xmods evo, xmods evolution
