EDS
06.16.2010, 11:47 PM
I finished the battery compartment today. It is a quick release set-up. At one end is a screw that acts as a hinge while at the other end their is a pin (screw) that I cut the top off and screwed on end into a thumb screw. You unscrew the rod using the thumb screw and then pull the pin and the battery strap can pivot upwards. On the side I decided to do some work with the scroll saw and cut out the buggie's name. I will be painting all these parts since they are lexan. Next I just have to finish up the back of the buggy and make wing mounts and body mounts. I'll be working on that stuff tomarrow and friday.
Finished pictures.....Saturday night.They will be posted on my website www.Teamkassanova.webs.com before anywhere else.
