If you did not replace the bearing with the diff gears, then that could be the problem. The only diff parts that wear out in my Muggy are the bearings on the rear diff pinion. Then the gears can slide past each other under hard acceleration as the pinion deflects because of the wear in the bearings. Check it out.
