Thread Tools Rating: Thread Rating: 58 votes, 5.00 average. Display Modes
Jahay
06.24.2010, 07:56 AM
Anyway just bought a few things... Want to keep all this up to date. I also need to think out loud and work out what else i need to get...
Purchased today...
- 2x 47t HPI Plastic Spurs ( i thought i would give these ago before the centre diff upgrade. Im tired of changing pinions and would prefer to change spurs.
- Gorilla Tape - hopefully this works better at strapping my tyres
- 40 series Moabs - only for jumping
- Axial over size in black - only for jumping
- Extra 29t idler tranny gear - i feel that i have been lucky as no gears have broken in the last 7 runs :) apart from my pinion
- Extra 32t drive tranny gear
- Extra wheel nuts
Things to order. Starting with the most vital:
- SHD Drive shafts
- SHD wheel Axles
- SHD Diff Axles
- Ofna spider centre diff 46t
- RCM Universal CD/Motor Mount
- 12t pinion
- Custom centre drive shafts
- Custom Plate For RCM Mount to bolt too.
- 80k CD diff fluid
- GH Steering assembly
- Racers Edge alloy servo horn
- Full BOCA Bearing Upgrade (not sure which ones) but im not going to skimp on quality here. my bearings are failing pretty quickly
ICE HV 160 ESC (MMMXL)
Hyperion lipos
- 1x 5s 5000MAH+ 35C
- 2x 2s 5000MAH+ 35c
= 9s
-GH Bulks? dont want to add more weight if i can help it. I think the Diffs will need to be soild so no movement is incurred when using 9s. I have a feeling my diffs will be the weak point.
- Decent Hyperion Charge duo
Anyone else see anything i should be adding which i do not have already?
