What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
06.28.2010, 07:44 PM
If it is just the coil, then it's highly fixable. The question is, do you have the time to put into fixing it? It looks like the coils are glued in. Obviously soldered on the other side, and would likely require a powerful iron to remove. Then there is parts availability- or you could rewind the core (probably easier than trying to find a replacement).
