its looking real good! But i think we are yet to see a full blown full throttle pass!!!
I think you are going to need to get some road tyres and do the fishing line method as well as strap them.
Well, I didn't consider the crash to have a public value. It was not very harsh, but the tie-rod wasn't geared to handle 6kgs rolling around. It will be permanently fixed during this week..
It was actually a attempt to slowly pull up to full throttle, but then reality came by for a visit
Here's the vid. Just uploaded it, so quality will improve over time.
Did a small test-run in my garden. The "garden" is 5 by 5 meters of grass, with the water sprinkler in the center. A few burn-outs around the sprinkler resulted in even less grass, and a graph to post here
Yesterday I did some grass driving. On 2:30 minutes apx 30Wh was spent => I should be able to drive at least 10 minutes. Peaks of 130Amp, temperature rising quite linear during those minutes, but I still have no cooling in place.
However did the test result in a a few stripped gears. Clearly from the landings.. I think it was the ordinary hardened gears, and not the bullet proof ones, but I'll see later today.
I'd have to say that the voltage is keeping up very well on this 14s1p3300mAh Hyperion packs..
