Jahay
07.08.2010, 09:06 AM
if i were you, i would recommend doing a centre diff conversion immidiately.
Not only will this give you as much space as you want for a motor to fit, but it will also eliminate the weakpoint which is the tranny. It can barely handle my motor so i believe a 1527 would be worse. What kv rating is it? and what lipos are you going to power it with?
