brushlessboy16
brushlessboy16's Avatar
07.16.2010, 10:35 PM
Originally Posted by DwightSchrute View Post
i installed the losi mount earlier today, and i find it to be an amazing improvement over an already great design.
i LIKE that the top screw is what holds the whole motor in. i NEEDED a quick change mount. the losi's mount sucked, and elite's has been long gone.
I used Mike's motor cover and drilled the 3mm holes to 4mm so it would be stronger on higher jumps. i threadlocked everything in and took some high jumps this evening.
WOW...this mount is STRONG. no flex at all. imo, it does fit better than the first mount too.
it took a great beating and stayed strong. i need more of these for my other rides. this is a GOOD improvement.
i also would like to get a hold of a few more of those black aluminum spacers used in the bottom hole. it would be nice to be able to have 2-3 motors ready with them already assembled to the motor so i can just unscrew the top hole and drop a new motor in.
Truely, i think Mike has out done himself. this is a great piece of engineering.
Are you using the bottom plate/standoff, I hear it fits pretty good.... I know the guy that designed it
