scarletboa
scarletboa's Avatar
07.19.2010, 09:02 PM
Originally Posted by jamesban View Post
I wanted to put some truggy wheels on my LX-1E if possible. Im not going to lengthen the arms or anything just throw some stablemaxx wheels on it. Would this be possible with gearing down. Would I have to go with a larger spur or can I go low enough with the pinion to run it safely?
You would also need a longer chassis for it. If you do get a longer chassis, please, let if you if you are willing to sell the stock chassis. I bent mine pretty bad and I could use a cheap used one.
