Pdelcast
Pdelcast's Avatar
07.20.2010, 10:36 AM
Originally Posted by FG101C View Post
Ok, updated the firmware on both my MMM and MMP. I see a problem. If I barely give throttle the car creeps forward, then jerks forward to almost full speed for a second them calms back down, if I hold the throttle just barely it continues to do this lurching forward then slow then lurching again.
This is in two cars two separate esc's, MMM and MMP. Going back to previous firmware.
Try this--
Turn off punch control. Set torque control to "7".
Try driving and see what it's like. If you get lots of wheel spin, try setting torque control to half the value (3.5)
Remember, higher values means MORE torque is allowed. Lower values means less torque allowed.
Torque control is designed differently than punch control. It doesn't ever limit the throttle change, but limits the amount of torque that the motor is allowed to make.
Play with it a bit. We are still refining the software. :)
Patrick del Castillo
President, Principle Engineer
