Wanderer or Feigao -
02.22.2006, 10:55 AM
I finnaly sold my basic xl3100, to fund some more upgrading. My emaxx has all RPM stuff, MIP bones, Maximizer diff cups which puts it in the 12-13 lbs. range. I plan on going to either a Wanderer or Feigao 9 or 8 something with a strobe slipper. Which motor would be best running on 12-14 cells? I have several GP3300 packs now, but will buy 14 cell packs next time. Also, what pinion tooth would I need? I want to run in the 40-50mph range. i do not race but may. Have stock tires, and I will try to go convert to the single speed trans, depending on how much $ is left over. Also, I already have a Warrior 9920 controller. Future plans include G-Maxx single spped conversion w/ steel idler, G-mass G2 carbon chassis.
Thanks for the advice and education!
Do you know who is watching....
RC-Monster Custom
02.22.2006, 11:00 AM
Wanderer 8xl or 9xl. They got better bearing's than the feigao's.
Gearing I don't know.
02.22.2006, 12:30 PM
For 12-14 cells i would take a 7XL, a 9XL is nice, if you are planning on going to run 20 cells, and the 8XL is nice for about 18 cells.
Gear with sense, in about the 35-40 mph range and you'll be save.
RC-Monster Custom
02.22.2006, 12:36 PM
Ok i'm so confused right now. In other topic's I read people suggesting the 8xl for 12-14 cell's, but not 18 cell's cause it run's to hot.
02.22.2006, 12:57 PM
the 7XL can handle 18 cells, but runs a bit hot.
for these low amount of cells, the 7XL gets my vote.
02.22.2006, 04:00 PM
Okay I can go with an 7XL. I do not plan on ever going higher than 16 cells. What gearing would be needed?
02.22.2006, 04:07 PM
Also, my 9920 has the same conncetors that came on the Lehner xl3100. Not sure what size connecttors they are. I see the Wanderer has 5mm connectors. Any possiblity there are the same? Is the Wanderer 7XL in stock, and the Strboe slipper kit?
02.22.2006, 05:34 PM
the wanderer has the 5.5mm connectors but the lehners have 3.5's. you will have to change them.
02.22.2006, 06:35 PM
Mike:
I see that you are out of the Wanderer 7XL, Strobe slipper kit, and i hope you have 5mm connectors, (didn't see them). Any idea when??? Let me know. As soon as I find out what gearing to use, I will need pinions too.
Thanks
02.22.2006, 06:55 PM
7xl gearin 18 cells 14 tooth 16 cells 15 tooth 14 cells 16 tooth. Email mike he don't get on much any more. mod1
